qdude Posted August 6, 2010 #1 Posted August 6, 2010 I traded some BUBS for a set of Tour Deluxe factory mufflers. The TD dpipes arrive today and the opening to the pipes is 1/4 inch bigger than the BUBS, in fact the the BUB muffler opening will slide into the TD muffler opening , aren't they supposed to be exactly the same? I tightened down most of the set screws but I am uncomfortable going much tighter. The exhaust is leaking at the end of the header. What I am i doing wrong?
Freebird Posted August 6, 2010 #2 Posted August 6, 2010 Do you have the gaskets installed? The stock mufflers use gaskets where they slip on. Some of the aftermarket ones do not. I'm not sure about the Bubs.
Condor Posted August 6, 2010 #3 Posted August 6, 2010 Didn't someone make a reducer/adapter for those things??? Used when Harley Road Kings were installed...
qdude Posted August 7, 2010 Author #4 Posted August 7, 2010 No gaskets and the BUBS didn't use them. Trip to Yamaha tomorrow.
Freebird Posted August 7, 2010 #5 Posted August 7, 2010 Yep...that's your problem. I went through the same thing when I went from a set of Khromewerks to a stock set of Tour Deluxe mufflers.
