Does it do anything different when you are below speed or up to the speed where it can be set? I so that eliminates the vehicle speed sensor. If that checks out I would check the hoses and the wires going to the module and to the switch. I am sure there is a connection in the fairing. I will look in my tech manual tonight and see if it has any trouble shooting info. It is digital so I could email it to you. I purchased it on Ebay for 6 or 7 Bucks it is pretty comprihensive.
Oh yea check both brakes make sure your brake light is going off.
Have you been in the lower farings lately. If a vacuum hose slips off you will get that error. I had mine in the shop and when I picked it up on the ride home no cruise. Just the light blinking. Went back to the shop and found the mechanic had left a hose off.
Is it like the one in the Tech Library or better,, I could use one that is good, and covers most things, that you can copy pages to look at.
next time this happens, push your clutch lever away from you.. gunk gets in the switch and will set the code that you are seeing..
clean the pivot piont and switch area of your clutch lever.
mike
Behind the lower cowl was clip that just was not quite tight. Snapped it tight and it works. Thanks to everyone for you fast help. My dealer couldn't get to it until the 19th!
