Cruser Posted August 3, 2010 #1 Posted August 3, 2010 Does anyone know where I can get one? or what other method lets you know when enough is enough oil in the final drive?
dingy Posted August 4, 2010 #2 Posted August 4, 2010 Here is a picture of one and the dimensions. 6.55mm (.258") from the flange to the first line, 6.8mm (.267") to the second line on the "middle" (Right) side 2.35mm (.092") from the flange to the first line, 2.55mm (.100") to the second (outside) line on the "rear" (Left) side. You only need these on 83-85 Ventures. The 86-93 are filled to the bottom thread of the fill hole. Case casting is different on the MKII's. Gary http://i1007.photobucket.com/albums/af193/gdingy101/P1030757.jpg
