bikerjohn Posted August 3, 2010 #1 Posted August 3, 2010 Has anyone used Rotella oil? A buddy of mine said he used it on his venture with no issues. What type of Rotella should I use if any?
flb_78 Posted August 3, 2010 #2 Posted August 3, 2010 yup, I use Rotella T, the standard white bottle oil. Many use the newer Rotella T6 synthetic oil. Either one will work.
slick97spirit Posted August 3, 2010 #3 Posted August 3, 2010 I use the Rotella synthetic in the blue jug. No issues
wes0778 Posted August 3, 2010 #4 Posted August 3, 2010 Got the T6 (blue jug) in both my bikes. No problems. The RSTC had Suzuki (dyno) oil in it when I bought it. Shifts better with the Rotella. The RSV had Mobile 1 in it when I bought it. Don't know if I can really tell much difference in it with the Rotella.
OB-1 Posted August 3, 2010 #5 Posted August 3, 2010 We use the Synthetic version in our 06 Midnight Venture. No problems, no issues, no oil consumption.
massey130 Posted August 3, 2010 #6 Posted August 3, 2010 there are many comments on oil. I use yammy dino oil. that's what was in it when i bought it, it runs fine, so i am not going change anytime soon. i use the purolator oil filter that someone recomended. if you do a search on oil, you will find many threads with a lot of material to read. nice thing is, another 3k miles and you can try something different, how cool is that.
gibvel Posted August 3, 2010 #8 Posted August 3, 2010 The RSV had Mobile 1 in it when I bought it. Don't know if I can really tell much difference in it with the Rotella. Sure you can, your wallet is fatter!!
KiteSquid Posted August 3, 2010 #9 Posted August 3, 2010 See my signature..... BTW it is JASO MA compliant so your warranty is ok.....
N3FOL Posted August 3, 2010 #10 Posted August 3, 2010 If you want to save a few bucks per oil change, Rotella 15W40 Oil is a good choice paired with a Purolator long filter. That is what I've used after switching from Valvoline moto oil. So far, the oil met my expectations.
Jethroish Posted August 3, 2010 #11 Posted August 3, 2010 Rotella Syn in blue jug with a Wix filter. Change every 5000 miles.
mrich12000 Posted August 3, 2010 #12 Posted August 3, 2010 I switched from Motul to Rotela 15 40 and the Clutch slip stopped, great stuff. You shouldn't have to change that often since it is a truck oil their service intervals are longer since the oil stock is hardier:witch_brew: than the other oils.:banana:
