frankc Posted August 2, 2010 Share #1 Posted August 2, 2010 Good Morning Everyone! I'm about to ride the Blue ridge 2 up on my 08 RSV. I was wondering if anyone would suggest to me what I should check over before I go. I presently have 10K on the bike and will be riding about 1200 miles. Thank you for your suggestions. Frank Link to comment Share on other sites More sharing options...
Eck Posted August 2, 2010 Share #2 Posted August 2, 2010 Not sure when you plan to leave for this trip, but if you have the time.... Make out an emergency contact card and hang it around your neck every time you get on the bike. Being out of state, no one will know you or who to contact in the case of an emergency. Check your brake fluid and clutch fluid levels. Change you oil and Filter now (unless you did so not to long ago) If time permits, remove the rear wheel, clean and grease those hub pins. Tires seem to last around 7 to 10k miles on the RSV.. Make sure your tires don't need replaced before leaving for this trip. Take a coat.. It gets cold up there in those mountains... Adequate rain gear will be required.. Cell phone charger... Mine was hooked directly up to the bike in the trunk.. it could be charging while I was riding.. Take a map.. just in case your GPS goes Ka-put... Take extra Fuses...and some tools.. Take me with you............ Link to comment Share on other sites More sharing options...
midnite Posted August 3, 2010 Share #3 Posted August 3, 2010 Check oil levels, check air pressure in tires and shocks, lights, check over all bolts on bike especielly on the tour pac.:thumbsup2: Hope this helps, have a great ride. Watch for deer and cars. Link to comment Share on other sites More sharing options...
painterman67 Posted August 3, 2010 Share #4 Posted August 3, 2010 post up dates that youll be on the blue ridge . There are a few of us that are close enough to maybey get a day in and meet up with you and also be able to help if kneeded. Id try to download the vr members that are willing to help with problems. I think there is a list on the site somehwere. David Link to comment Share on other sites More sharing options...
frankc Posted August 3, 2010 Author Share #5 Posted August 3, 2010 If all goes well I'll be leaving Pittsburgh area Aug 28, This is the first long trip I will be taking on the bike so thank you for all your suggestions. I already changed the tires and lubed the hub pins but other than that I thought I would take advantage of the advice from those of you who take longer trips more frequently. Thanks Again Frank Link to comment Share on other sites More sharing options...
TARHEEL RIDER Posted August 3, 2010 Share #6 Posted August 3, 2010 DON'T FORGET THE ANTI MONKEY BUTT POWDER!!!! Link to comment Share on other sites More sharing options...
AKRefugee Posted August 3, 2010 Share #7 Posted August 3, 2010 Since you are riding two up make sure you put some blue Loctite on the passenger grab handle bolts. Link to comment Share on other sites More sharing options...
jburrell Posted August 3, 2010 Share #8 Posted August 3, 2010 Have a great time? Take a tire repair kit and maybe add "ride on" to your tires for safety. I am heading that way in late septemter. Everyone has great ideas here but one that may be better than a card around you neck is to add an entry into your cell phone for an Emergency contact. It should be entered as ICE then name and number. I-IN C=case E Emergency IN CAse of Emgergency. EMT's etc will look for this if something happens. Be sure to check your bike often for loose bolts etc. And as mentioned, take a coat and be sure to take along water and keep hydrated. You may not realise that the heat and wind is taking a toll, until too late. Drink lots of water while riding in august weather. Again have a great time and be careful. Remember the turns on that road can be dangerous and several have died this year on it due to not being able to make the turns due to speed. Make it back ok and then post your pictures for us to envy. jb Link to comment Share on other sites More sharing options...
dray Posted August 3, 2010 Share #9 Posted August 3, 2010 kick the rear tire look at the front tire as your putting on the helmet fire it up if she aint a knockin Oil is fine NOW GO HAVE A GOOD TIME!!! sure wish i could go dray Link to comment Share on other sites More sharing options...
