Cruser Posted July 31, 2010 #1 Posted July 31, 2010 I re soldiered the connections on the circuit board for the class system errors I was getting, re installed the unit hooked up the battery turned the key to acc, the controller came on no errors showing sounds great so far but read on , switched it to manual and pushed increase, all the power on the bike went away except to the controller? I have no power to anything else. what the heck happened? I checked all the fuses, the main fuse looks ok through the window but it could be bad where I can't see it at.
Cruser Posted August 1, 2010 Author #2 Posted August 1, 2010 Its all better now, just a little battery connection problem! The class system is working great!!
Dano Posted August 1, 2010 #3 Posted August 1, 2010 Ya gotta love it when it's just the simple things! Like I told my son the other day while he was working on his car, always start at the beginning and check everything twice! Makes repairs alot easier that way! Glad you got it fixed for good, now you can go ridin'!!!!!!!
