Freeman50 Posted July 27, 2010 #1 Posted July 27, 2010 What carb can i use on my 1983 venture that i can bolt it on and just go:confused24:
skydoc_17 Posted July 27, 2010 #2 Posted July 27, 2010 Hey Rick, You are looking for a set of Carbs. from any of the 1200c.c. motors, 1983 to 1985. Keep in mind that when replacing one of the Carbs, they will be location specific, in other words, a right front Carb. will not fit the left rear position. Good luck with your project, Earl
Condor Posted July 27, 2010 #3 Posted July 27, 2010 What carb can i use on my 1983 venture that i can bolt it on and just go:confused24: I'm just assuming here, but I think you mean the entire 4 carb assembly. The '83 was sort of a 'beta' model, and unfortunately the only 'bolt and go' set would be from another '83. Other sets can be run, but they take a little more than bolt and go....
