karlos Posted July 25, 2010 #1 Posted July 25, 2010 Had a problem start this year. When I hit a bump the speedometer needle would shake a little. While on my long trip it got worse, sometimes to the point where it would drop right to zero, then come back when I hit another bump. This also takes out the odometer and the cruise control. I have removed the fairing and lowers and checked all wiring since it seemed it was when the front hit a bump the problem occurred. I also took all the connectors apart, checked them and put back together. Still same. Any ideas? Thanks in advance
Freebird Posted July 25, 2010 #2 Posted July 25, 2010 Have you had any problems with the bike not wanting to start? There is a set of contacts in the ignition switch that can fail and cause the dash to do out but usually the bike won't start either. The RSV is sort of known to have switch failures though.
Squeeze Posted July 25, 2010 #3 Posted July 25, 2010 Sounds a bit like a Sensor or Sensor Signal Problem. The Sensor is located in the final Drive. You might check the Wire and the respective Connectors first.
LilBeaver Posted July 25, 2010 #4 Posted July 25, 2010 karlos said: Had a problem start this year. When I hit a bump the speedometer needle would shake a little. While on my long trip it got worse, sometimes to the point where it would drop right to zero, then come back when I hit another bump. This also takes out the odometer and the cruise control. I have removed the fairing and lowers and checked all wiring since it seemed it was when the front hit a bump the problem occurred. I also took all the connectors apart, checked them and put back together. Still same. Any ideas? Thanks in advance What kind of bike is this? When you say it 'takes out the odometer and the cruise control' do you mean that the odometer turns off, stops counting, trip odometers reset to 0, or what? Squeeze's notion of the speed sensor sounds reasonable. I'd also check for loose connections to ground.
Greener Posted July 25, 2010 #5 Posted July 25, 2010 Squeeze said: Sounds a bit like a Sensor or Sensor Signal Problem. The Sensor is located in the final Drive. You might check the Wire and the respective Connectors first. Since you've already checked all the connections under the fairing, checking the sensor at the final drive and working your way forward sounds like a good next step. Is it possible something might have come loose when you had the back wheel off for your tire change?? Just a thought.
