Guest tx2sturgis
Are you just draining the coolant? If so, unscrew the hex bolt drain plug. I cant remember the size exactly, something like 12mm, or close to it.
Rad has to be loose as if memory serves me correctly it's a tight fit with the hose at a dead short 90 degree angle......and a lot of patience
:whistling:
