starkruzen Posted July 21, 2010 #1 Posted July 21, 2010 I'm vertically challenged. About 30" inseam and I can't get flat footed on the ground. Any advise on the easiest way to lower the bike about 2"? As always, any assistant you could afford me will be greatly appreciated. By the way, I have a 2007 RSTD.
starrider60 Posted July 21, 2010 #2 Posted July 21, 2010 HAD THE BARON'S KIT INSTALLED BEFORE I RODE THE BIKE OUT OF THE DEALERSHIP. I HAD RIDDEN THREE VENTURES PRIOR TO BUYING MINE. I COULD GET MY FEET DOWN BUT WAS NOT COMFORTABLE, SO... ALSO LOWERED THE FRONT. I'LL LEAVE IT THAT WAY.
elmicko Posted July 21, 2010 #3 Posted July 21, 2010 Being Vertically Challenged also, I had the same issue with my 1st Gen. Really couldn't find a good way to lower it so I shaved the padding in the seat down about 4 inches and actually made it more comfortable. One interesting thing I did find in the process was if you narrow the front of the seat where it meets the tank, it will give you a much better stance to get your feet on the ground. The narrowing actually helped more than shaving off the height.
Jerry W Posted July 21, 2010 #4 Posted July 21, 2010 I am not thinking you can lower the front on the RSTD like you can on the RSV. I have my RSV lowered both front and rear, but I believe the only way you can lower the front is by purchasing a kit vs. sliding the forks up. However, lowering the rear should be the same. You might try lowering the rear and going with the smaller tire on front as some of the members have done. I don't remember what size tire they used on front.
KiteSquid Posted July 21, 2010 #5 Posted July 21, 2010 DON'T lower the motorcycles suspension. Get some of the padding cut out of the seat and have the nose of the seat narrowed.
frogmaster Posted July 21, 2010 #6 Posted July 21, 2010 Same here 30" inseam 2008 RSV. 1. Rick Butler Seat Mod 2. 1" Heel on Motorcycle Boots not flip flops This makes me flat footed on a Stock 2nd Gen 2008 RSV
starkruzen Posted July 21, 2010 Author #7 Posted July 21, 2010 Will the Butler seat mod work on an Ultamate seat?
Jerry W Posted July 21, 2010 #8 Posted July 21, 2010 You might send Rick a note asking about getting your seat narrowed and shaved down. I didn't mention that I have also had Rick Butler rework my seat after I had lowered the bike. I am very satisfied with both modifications. I know several who have lowered their bikes and would not go back to stock height.
KiteSquid Posted July 21, 2010 #9 Posted July 21, 2010 Remember that when you lower a bike you increase the minimum turn radius and that MAY effect you in emergency maneuvering. Just try to be safe.
Jerry W Posted July 22, 2010 #10 Posted July 22, 2010 The Yamaha starts off with 1" more ground clearance than the Harley Ultra. For me, giving up 1" doesn't really create a hazzard for me. Guess each one needs to look at their own bike and do what is right for them. Yamaha Royal Star Dimensions Ground Clearance (in) : 6.1 2010 Harley-Davidson Ultra Classic Electra Glide FLHTCU Dimensions Ground Clearance 5.10 in.
