mshowe Posted July 20, 2010 #1 Posted July 20, 2010 I am considering purchasing a 1983 with 33k on it. Could someone tell me, do all 2nd gears go out? If so, is there a typical mileage? Can anything be done to help prevent it? When/if it does go out, can one still ride the bike without 2nd gear without fear of further damaging things? Thank you from a newbie to the forum.
mini-muffin Posted July 21, 2010 #2 Posted July 21, 2010 Yes all the 2nd gears will go out usually around 62000 miles or so. Some can go early some a bit later. You can do the fix or get a tranny out of a Mark II (86 - 93). Then the problem will be solved for good. Margaret
Rocket Posted July 21, 2010 #3 Posted July 21, 2010 I am considering purchasing a 1983 with 33k on it. Could someone tell me, do all 2nd gears go out? If so, is there a typical mileage? Can anything be done to help prevent it? When/if it does go out, can one still ride the bike without 2nd gear without fear of further damaging things? Thank you from a newbie to the forum. You could do the 2nd gear work preventativly, over the winter downtime. Some just bypass 2nd gear, as they have not gotten around to fixing it.
