Cruser Posted July 18, 2010 Posted July 18, 2010 sometimes my class system gives me an E1 error and other times it works just fine. any thoughts on whats causing it?
Freebird Posted July 18, 2010 Posted July 18, 2010 Most likely a back solder joint. Check this thread. http://www.venturerider.org/forum/showthread.php?t=493
skydoc_17 Posted July 18, 2010 Posted July 18, 2010 Hey Cruser, Try opening the coolant bottle fill door, right above the Air Ride Controller. You can then access the large plug that connects the compressor electrical to the Controller box. Remove the plug, clean with CRC, Apply some conductive grease, and see if that helps. Also, with the lid open, try wiggling the plug and see if the Controller works. Sometimes the wire gets bound up and a good wiggle works wonders. It works for Jean! Earl
Yammer Dan Posted July 18, 2010 Posted July 18, 2010 Hey Cruser, Try opening the coolant bottle fill door, right above the Air Ride Controller. You can then access the large plug that connects the compressor electrical to the Controller box. Remove the plug, clean with CRC, Apply some conductive grease, and see if that helps. Also, with the lid open, try wiggling the plug and see if the Controller works. Sometimes the wire gets bound up and a good wiggle works wonders. It works for Jean! Earl You going to pay for that one!!:rotfl:
