I have one mounted on the right side where the stock horn was but I always wanted to put one in the fairing as well. Is there a good tutorial and pictures on how to do this and still keep my existing stebel on the right?Thanks
There's info on installing a pair of Fiamm extra loud electrics inside the fairing here, but I've never seen a Stebel there.
The Fiamm info is about two thirds of the way down the page. They are pretty loud at around 130 dB, and work well mounted inside the fairing. I've seen these horns sold at Pep Boys and Autozone.
I've got one electric Magnum horn under the fairing and another under the lower left cowling where the other stock horn mounted.
All I did was tie in with the Stebel air horn with new 14 gauge wire from the Stebel horn relay.
You do lose a bit of volume being under cover but they're still plenty loud.
Larry
It does not mater where they are located for the wiring, just hook the second horn up in parallel with the first off of the relay. Make sure that all of the wiring and fuse can handle the amps for 2 horns.
