I'm headed back to GA and my pull cable on the throttle just broke. Anyone near here?
I'm going to try and hook the push cable to the pull side.
I have a used one I could overnight to you.
Upper or lower cable.
Gary
Todd,
If your in Lancaster SC here is the # of a motorcycle dealer Team carolina powersports
1200 Highway 9 Bypass West, Lancaster, SC‎ - (803) 285-5893‎ -
Sorry, that's all the help I can be from here. Good luck!
Thanks, but I have to be at work in the morning. I've got the airbox off but not sure how to get the cables loose. Do thet carbs need to come off to swap them?
Hey Todd... Got your cell phone message about the throttle cable. You were really breaking up so only caught bits and pieces of what you were saying. Kinda thought you were local and was ready to climb on the horse and come rescue you. White hat and all.... :) Anyway to answer your question about undoing the cables, the only way I've been able to do it is by removing the carbs, and it's a PITA. If anyone has a better way com'on over and show me 'cause I ain't gonna believe it until I see it in person. My suggestion would be to rent a trailer if someone on this board doesn't offer one up, and take it home. If you're pulling a trailer renting may be the only way to go to get one long enought to handle both units. Good luck.....
Edited by Condor
Todd,
Is there any way you can find where it broke and use a vise grip to hold the ends together temporarily to get you home? You might have to cut away the sheathing. That's an old Harley riders trick.
I'm not sure if it is the same on the Rsv as the RSTD, but I was able to remove both cables without removing the carbs. You'll need a long screwdriver or scribe to get the swedge out of the bellcrank. Not too bad of a job. I'm not sure if the cables are the same length. You might need to swap them at the grip end too.:178:
U can get to them with the airbox off. I got the cable swapped and tied off to the front Carb. Ill posts pics later. If I can get the airbox back on I'm out of here.
Thanks Y'all.
I just looked up Yamaha in Lancaster SC. Here is the info on the one in Lancaster.
Bullet Powersports
1200 Hwy 9 Byp W - Lancaster, SC 29720-1780
803-285-5893, Fax 803-285-4993
You might get luck and they have one in stock:fingers-crossed-emo
If 86er swapped his cables does that mean he will have reverse throttle control? like instead of throttle slowing down you would actually be giving more fuel? Good luck the restof the way home.
As George said, I got home OK at about 9pm with just a few "interesting" moments. Yes, when you swap the cables you reverse the control. You roll your hand forward to accelerate. You just have to stay aware. I have been mainly using my truck for the last few days but I went to bike night and rode to work today.
Before all this happened, I was planning to pull my trailer, with tools, to a bathroom remodel, but decided to take the truck thru' Atl. traffic!
I went to a bicycle shop today and bought a few cables and some generic ends, but after looking at things I decided to order the right cables from Flatout MCs at about 60 bucks. I'm gonna replace all but the cruise cable. A friend of mine said that I need to replace the cables every one hundred and fifty thousand miles and not go 150010 miles, which is where I changed my oil.
I want to thank everyone that responded to this thread. I was working with my smart phone. That is what is so great about this website. Sleeperhawk was ready to drive a couple of hours to come pick me up; hell, Condor was going to drive over here from Cal-I-Forn-I-A. The problem was that if I didn't make it to work on Wednesday, I would lose my holiday pay.
