uechi kid Posted July 4, 2010 Posted July 4, 2010 We own a RSV and it's now time to start doing my own maintenance (no more local dealer). So I'm buying the tools to do a carb sync and I start thinking about my Suzuki M95/ MS. Do we need to sync the carbs on our V twin's? I've never seen a post about that.
Snaggletooth Posted July 4, 2010 Posted July 4, 2010 If it's got more than one carb................balance is good.
flb_78 Posted July 4, 2010 Posted July 4, 2010 I thought all V Twins had ONE carb. (?) Craigr Most do, but not all. I know one of the v-stars has 2 carbs, but the Roadstars only had 1.
uechi kid Posted July 5, 2010 Author Posted July 5, 2010 OK, just realize why I don't see any posts about Syncing late model V twines. FUEL INJECTION!! http://www.kawasakimotorcycle.org/forum/images/smilies/icon_sad.gif Sorry and Thanks
flb_78 Posted July 5, 2010 Posted July 5, 2010 If it has 2 throttle bodies, you still have to sync the throttle bodies to each other.
tpalshadow Posted July 5, 2010 Posted July 5, 2010 I have a 72 Honda that doesn't have vacuum carbs, does have two carbs. The manual says to hold your hand behind the muffler and make sure the pressure coming out is the same in order to sync the carbs. Problem is the pipes are 2-in-1 Scrambler pipes. Anyone have any idea how I can sync them? I have used a laser heat reader on the headers, seems to work OK, but not great. (sorry for jackin' the thread!) http://theuprightmotorcyclebrigade.files.wordpress.com/2008/08/1972_honda_cl175.jpg
RandyR Posted July 5, 2010 Posted July 5, 2010 I have a 72 Honda that doesn't have vacuum carbs, does have two carbs. The manual says to hold your hand behind the muffler and make sure the pressure coming out is the same in order to sync the carbs. Problem is the pipes are 2-in-1 Scrambler pipes. Anyone have any idea how I can sync them? I have used a laser heat reader on the headers, seems to work OK, but not great. (sorry for jackin' the thread!) pull the muffler off the pipes while balancing.
Squidley Posted July 5, 2010 Posted July 5, 2010 We own a RSV and it's now time to start doing my own maintenance (no more local dealer). So I'm buying the tools to do a carb sync and I start thinking about my Suzuki M95/ MS. Do we need to sync the carbs on our V twin's? I've never seen a post about that. OK, just realize why I don't see any posts about Syncing late model V twines. FUEL INJECTION!! http://www.kawasakimotorcycle.org/forum/images/smilies/icon_sad.gif Sorry and Thanks Rick, There is a few things that aren't adding up to me here with your statements. If you inquiring about your RSV, then there are 2 things here you need to know. #1 It's a V4 not a V twin #2 It's not FI on any RSV's there are 4 carbs on ALL RSV's so yes you definitely need to sync them. If what I have said has made things a bit clearer, then I would invest in a Carbtune synchroniser tool. It will sync carb from 2 to 4 carburetors, I have done inline twins, V twins, triples and 4 carbs with mine. Here is a link to purchase one directly from the mfgr.... http://www.carbtune.com/carbrevw.html I bought one from Sean Morgan 2 years ago and it was the best investment I have made. I'd wager that I have used it on 100 different motorcycles.
Guest tx2sturgis Posted July 5, 2010 Posted July 5, 2010 Wow...I got dizzy reading all 10 posts right in a row....
flb_78 Posted July 5, 2010 Posted July 5, 2010 He's asking if he needs to synch the throttle bodies or carbs on his Suzuki V-twin M95.
flb_78 Posted July 5, 2010 Posted July 5, 2010 I start thinking about my Suzuki M95/ MS. Do we need to sync the carbs on our V twin's? I've never seen a post about that.
uechi kid Posted July 6, 2010 Author Posted July 6, 2010 OK, I have two bikes. A RSV which has four carburators and an 04 Suzuki M95 V twin which is fuel injected. In my research I have found that a multi throttle body fuel injected V Twin needs to be synced. Now I'm trying to find out if the M95 has two throttle bodies. My service manual NEVER discusses synchronizing the throttle bodies. Which leads me to think there is one throttle body that feeds two cylinders.
Squidley Posted July 6, 2010 Posted July 6, 2010 OK, I have two bikes. A RSV which has four carburators and an 04 Suzuki M95 V twin which is fuel injected. In my research I have found that a multi throttle body fuel injected V Twin needs to be synced. Now I'm trying to find out if the M95 has two throttle bodies. My service manual NEVER discusses synchronizing the throttle bodies. Which leads me to think there is one throttle body that feeds two cylinders. OK that make a bit more sense to me now. If the are are 2 butterflys then yes they need to be synced. Is there a parts breakdown list on Suzukis website like Yamaha where you can get part #'s. You could look at an exploded view of the fuel bodies and see from there.
Guest tx2sturgis Posted July 6, 2010 Posted July 6, 2010 Now I'm trying to find out if the M95 has two throttle bodies. My service manual NEVER discusses synchronizing the throttle bodies. Which leads me to think there is one throttle body that feeds two cylinders. Take some good well lit close-up pics of the area between the cylinders, if you can get past the air cleaner. Post them here. We can probably look at those and make an educated guess. One website I visited refers to the throttle BODIES on an M95.
RandyR Posted July 6, 2010 Posted July 6, 2010 (edited) Apparently the M95 was a Kawasaki model OEM'd by Suzuki for only a short time. The Boulevard M95 is built by Kawasaki Heavy Industries and is a lightly restyled version of the 2005 Kawasaki Mean Streak 1600 Its the same as a kawasaki Vulcan Mean Streak 1600. http://www.bikebandit.com/houseofmotorcycles/2005-kawasaki-motorcycle-vulcan-1600-mean-streak/o/m4467 It has a dual-throat 40mm throttle body. http://www.bikebandit.com/assets/schematics/Kawasaki/KA-0705-01240.gif Edited July 6, 2010 by RandyR
uechi kid Posted July 6, 2010 Author Posted July 6, 2010 You can really see that there are duel throttle bodies in the Bikebandit schematic. Now I just need to find out how to synchronize them. Strange that the shop manual doesn't address this. Unless I missed it (been know to happen). Thanks everyone.
jasonm. Posted July 25, 2010 Posted July 25, 2010 I have a 72 Honda that doesn't have vacuum carbs, does have two carbs. The manual says to hold your hand behind the muffler and make sure the pressure coming out is the same in order to sync the carbs. Problem is the pipes are 2-in-1 Scrambler pipes. Anyone have any idea how I can sync them? I have used a laser heat reader on the headers, seems to work OK, but not great. (sorry for jackin' the thread!) http://theuprightmotorcyclebrigade.files.wordpress.com/2008/08/1972_honda_cl175.jpg Look carefully , even Honda had small screws in the intake somewhere, to allow using adapters to connect a sync tool.
tpalshadow Posted July 26, 2010 Posted July 26, 2010 Look carefully , even Honda had small screws in the intake somewhere, to allow using adapters to connect a sync tool. OK, I'll try to take another look tonight!
