With only 4,000 Km on my Venture, I had battery issues which caused me to require bump starting if there was a hill or a couple of willing BC Ferry workers to push the beast, or a jump start, which requires taking off the driver seat.
What a pain THAT is! Has anyone come up with an alternative to the awkward nuts that secure the seat?
My dealer replaced the battery, so I may not need to remove the seat for a while, but it would be handy to have an alternative for any future needs.
Thanks for any help.
Chris,
Many of us on the G2 dont even bother having the nuts on the seat. It's not coming off when you have a 300 lb guy (like myself) sitting on it. Also too I believe that Rick Butler here on the board has made thumb nuts for them for easier removal.
I believe the thumb nuts are a good product, but when the bike is hot I think the removal would be painful. I have a set of open/box ratchet that are stubby. I keep a 10mm in my trunk and they work quickly and keep you fingers off the engine top.
:farmer:
10mm regular depth socket and a 1/4" drive ratchet works perfectly for me on both sides. Can R&I both nuts without burning my hands.
While many suggest leaving the nuts off, I have found that if I don't have the nuts on I have two undesired effects. 1) My seat wobbles when I sit on it while riding - which I do not like 2) If the wind blows just right while my bike is parked, I end up playing the 'find my seat game' and with as much fun as THAT is, I don't want to have to do that again :o
i installed the battery tender hook up to my battery, then made a short jumper cable that plugs into the flat 2 connection.
i carry it in the bottom of the saddlebag in the event that anyone needs a jump, or if i need a jump.
the plug hangs out at the rt rear cyclinder head under the edge of the seat... no need to remove the seat.:whistling:mike
If you're patient sooner or later they'll fall off on their own. I've lost three so far, and I thought I'd tightened them adequately.
