Yammer Dan Posted July 5, 2010 Author Posted July 5, 2010 I use the Berryman's and usually mix a little Marvel Mystery oil with it. Don't know if it helps but I have heard that Berryman's is a little harsh if you use it strong so it makes me feel better.
Condor Posted July 6, 2010 Posted July 6, 2010 Never thought of that Squeeze. Good Idea!! I'm getting ready to buy one of the Ultra-Sonic cleaners big enough to dip one carb at a time. I'll try it in it maybe. Geeze Dan, If you value your life don't put any volital solvent in an ultrasonic cleaner.
BEER30 Posted July 6, 2010 Posted July 6, 2010 I'm staying away from yous guys . Either your all too expensive for me or ya want to Blow me up ! Warning for yous guys whom use Naptha .....wash your hands real GOOD before you go to the restroom. If you don't , you will learn a new dance real quickly ! Seafoam is not relatively expensive here where I am. I use at least 2 cans of it a year like FreeBird , but I ride year round. When I travel , I always carry a can of it with me just in case I get some watered down gas from some Jack-legged gas station. I generally dump 2 cans inside my boats fuel tank , as it has an 80 gal capacity and it's real humid here in NC . As far as a cleaner, I don't break my stuff as often as yous guys do . BEER30
Sailor Posted July 6, 2010 Posted July 6, 2010 Something which has been in use among boaters here for at least 70 years is methyl hydrate as a fuel stabilizer and water remover. It is very cheap and can be found in most boating supply stores. I have used it and found it effective.
OutKast Posted July 6, 2010 Posted July 6, 2010 I have heard that Marvel Mystery oil is mostly Auto Trans fluid. Check it out, as ATF is 99 cents vs. 4 bucks for marvel mystery oil. I will just buy the seafoam. Only use one can a year.
Yammer Dan Posted August 9, 2010 Author Posted August 9, 2010 (edited) Bring this back up this is what I mixed up. 1 Camp Fuel (Coleman) Don't know which is best one 2 Marvel Mystery oil. Thats the lube 3. Berrman's Chem Tech. It was on the shelf... 4 Don't use Isopropyl Alcohol. ( this stuff off the shelf is 50 % water now) After playing with this a while I found the Alcohol will not mix with others so I removed it . Percentages of each unknown even to me but it seems to work good. I feel the Marvel Mystery oil will keep the other things from being too harsh on things I don't want disolved. Still come up a lot cheaper than Sea-foam. This was less than 20 bucks a gallon. I bought a Gallon of Sea-Foam this year any way at 52 bucks a gallon. Got a "What?" from Warden on that one. Edited August 9, 2010 by Yammer Dan
Solodadof2 Posted August 9, 2010 Posted August 9, 2010 Well If you are using a gallon a year @ 52 a gallon you must be using this stuff anything that looks like it takes gas. this is a product that is awesome and I use is a couple times a year about 4 oz to a tank on the RSTD so 1 can last me a season for all my gos operated equipment. Not worth it to me to have more flammables than I need sitting around. Why reinevent the wheel? Of course it is Yammer Dan that should say enough!
Yammer Dan Posted August 9, 2010 Author Posted August 9, 2010 HEY! I got to play with something!! If you hear a Big BOOM watch out for falling 1st Gen parts!!
dfenrick Posted August 19, 2010 Posted August 19, 2010 Geeze Dan, If you value your life don't put any volital solvent in an ultrasonic cleaner. Just curious.... how volatile is 'volital', and what is the actual danger?
Rick Haywood Posted August 19, 2010 Posted August 19, 2010 I don't believe I would take a chance on my motorcycle by using something that MIGHT hurt the bike. But then again that's just me. I buy a can for $6.50 at TSC and go through about 4 cans a year. I figure it is worth it. Bikes only need about 3 oz's per tank about 1 time a month to keep things clean? Well at least that seems to work for me and I ride about 30,000 miles a year My cost on these ingredients Sea_Foam about $52.00 a gallon Marvel Mystery Oil little less than 4 bucks a quart. Camp Fuel about 8 bucks a Gallon BerryMan's Chem Tech 3 bucks 12 oz can. Sea-Foam is a great product and I know all about the cost of oil. But If I can come up with something that will do the job cheaper I will quit being a spokesman for them. My biggest fear was using something that would be too harsh on the seals and rubber pieces in the carbs.
Rick Haywood Posted August 20, 2010 Posted August 20, 2010 Retired gotta have something to do!! Well good luck on that.
Yammer Dan Posted August 20, 2010 Author Posted August 20, 2010 I don't believe I would take a chance on my motorcycle by using something that MIGHT hurt the bike. But then again that's just me. I buy a can for $6.50 at TSC and go through about 4 cans a year. I figure it is worth it. Bikes only need about 3 oz's per tank about 1 time a month to keep things clean? Well at least that seems to work for me and I ride about 30,000 miles a year I do a lot of things that could have ill effects. Running a 1st Gen at 115 MPH with only a front brake trying to catch a 2nd gen that snuck up on me. But I can't blame it on the carbs!! TCI on that piece of junk maybe....
etcswjoe Posted August 20, 2010 Posted August 20, 2010 My mixture of Marvel Mystery oil and Camp Fuel should be a good cleaner then. Need to add a little Isopropyl Alcohol maybe. If you add Isopropyl make sure you get pure, rubbing alcohol has soap or other fillers in it.
dingy Posted August 20, 2010 Posted August 20, 2010 If you add Isopropyl make sure you get pure, rubbing alcohol has soap or other fillers in it. Dan, You might want to try Ethyl alcohol, drugstores sell it, but it is not as common as Isopropyl alcohol. It is much purer than Iso. It will plainly say Ethyl on the label. Gary
Yammer Dan Posted August 21, 2010 Author Posted August 21, 2010 If you add Isopropyl make sure you get pure, rubbing alcohol has soap or other fillers in it. Yeah I'm not using the alcohol now it didn't want to mix with the other stuff.
Yammer Dan Posted August 21, 2010 Author Posted August 21, 2010 Dan, You might want to try Ethyl alcohol, drugstores sell it, but it is not as common as Isopropyl alcohol. It is much purer than Iso. It will plainly say Ethyl on the label. Gary I'll look for that.
KiteSquid Posted August 22, 2010 Posted August 22, 2010 I doubt a drug store will sell Ethyl alcohol (AKA ethanol) without denaturing it.
albyzee Posted February 5, 2011 Posted February 5, 2011 What ratio do you use with the Camp fuel to gas?
Yammer Dan Posted February 5, 2011 Author Posted February 5, 2011 I would use 1/2 & 1/2 for a good cleaning. Other than that couple ounces per tank.
albyzee Posted February 5, 2011 Posted February 5, 2011 I would use 1/2 & 1/2 for a good cleaning. Other than that couple ounces per tank. Sorry for not understanding but do you mean a half a tank of gas and a half of camp fuel? I would think you mean a few ounces to the tank otherwise.
DanC Posted February 5, 2011 Posted February 5, 2011 Am I missing something here. Why is all the talk about adding a fuel conditioner to the fuel. I have a 2008 venture and have never had to treat the fuel system as of yet with no problems. Is there something about the venture carbs that I am missing that they need to have the treatment added to the fuel system all the time? I feel as though I am missing something in this area and would appreciate someone setting me straight on this matter. I for the life of me can not understand what is the problem?? It is interesting reading all the articles concerning this subject to the point that people are making their own mixtures. I got to be missing something. :witch_brew:thanks in advance. DanC
Yammer Dan Posted February 5, 2011 Author Posted February 5, 2011 Preventive Maint. The crappy fuel we have to deal with today does not like to sit at all for any length of time. A little Sea-Foam now and then will keep carbs from getting full of crud. Keeping them clean is a lot better than the options.
albyzee Posted February 5, 2011 Posted February 5, 2011 But what about the camp fuel?? You said you use a half and half mix. The bike will still run with such a high ratio?
Flyinfool Posted February 5, 2011 Posted February 5, 2011 I would be careful adding a lot of camp fuel to the gas. The camp fuel has less BTUs per gallon and much lower octane. It means that you will have less power so you will get harder on the throttle and then the reduced octane will want to knock holes in the pistons. I have done a lot of testing with camp fuel in gas engines. An engine will run fine on camp fuel if it is tuned for it, typically reduced compression, and/or retarded timing, and it needs to be a little richer.
