tpalshadow Posted June 29, 2010 Posted June 29, 2010 (edited) OK, just curious here, I changed the coolant a few weeks ago and have had a slight drip out of the plug under what I am assuming is the water pump (what I used to drain the coolant). I went into the local shop and ordered the gasket for it (part 13 on the attached diagram). This is a metal part with a lip on one side. Is that the right part and if so, which was does the lip go. I was expecting a rubber gasket or something to hold the fluid in! http://images.powersportsnetwork.com/fiche/images/YAMAHA/1989/Motorcycles/327_waterpump.gif Edited June 29, 2010 by tpalshadow volcab issues
GeorgeS Posted June 29, 2010 Posted June 29, 2010 Is it leaking ?? the way you installed it . If not, I would just go for a ride !!! I hear its summer----
dingy Posted June 29, 2010 Posted June 29, 2010 I just pulled the drain bolt out of a spare water pump housing and the lip on the washer faced towards the bolt head. Gary
tpalshadow Posted June 29, 2010 Author Posted June 29, 2010 OK, thanks. Yes it is leaking (real slow drip), otherwise I would leave it alone.
MasterGuns Posted June 30, 2010 Posted June 30, 2010 Mine was leaking a drop or two every so often after reinstalling it. I just removed the crush washer and smoothed it up on both sides using 400 grit, applied a small amount of gasket sealer, and reinstalled it. No more leak even when really hot. I did however order a new washer and will use it if it ever starts leaking again.
MiCarl Posted June 30, 2010 Posted June 30, 2010 You should be able to pick up something similar at the corner auto parts store. The one by me has them in copper, aluminum and nylon.
