dcryamaha Posted September 15, 2006 #1 Posted September 15, 2006 what method do you use to remove and remount your own tires. I've seen 1 article on Harbor Freight tire changer. Is this any good? What do you use to balance them or take them to a shop? Thanks
BuddyRich Posted September 15, 2006 #2 Posted September 15, 2006 Tried to do it the hard way with 3 tiretools. Tire almost won. Bought the harbor freight changer and it works great. Static balance by letting it spin on its axle between 2 sawhorses. if it stops with the same side down several times that's the heavy side so you put a weight on the top and try again till it stops in a different place each time
Guest HdHtr Posted September 15, 2006 #3 Posted September 15, 2006 try again till it stops in a different place each time Different place? Like oh say Lodi, Modesto and Sacramento?
BOO Posted September 15, 2006 #4 Posted September 15, 2006 Tried to do it the hard way with 3 tiretools. Tire almost won. Bought the harbor freight changer and it works great. Static balance by letting it spin on its axle between 2 sawhorses. if it stops with the same side down several times that's the heavy side so you put a weight on the top and try again till it stops in a different place each time I don't change all my own tires but when I do I use the method used above. You just need to use something to protect the aluminum wheels so as not to scratch them up. Jerry
