Iowawegian Posted June 28, 2010 #1 Posted June 28, 2010 The hubby put a new battery in the 05 Venture and now our head sets don't work.....I tried finding a thread about the subjet but didn't find anything....anyway, the hubby has been swamped and hasn't had time to read the manual. My question is...when you change the battery, does he need to reset the radio/speakers/etc? and if so is it easy? Thanks Deb
gibvel Posted June 28, 2010 #2 Posted June 28, 2010 Does the radio play on the speakers? If it's a matter of changing from speaker to headset yes it's very simple. Turn on the radio (audio button), press the select button, use the large "up and down" button on the left side of the controller (not the round knob) to change it from SP to HS and you're done.
Iowawegian Posted June 28, 2010 Author #3 Posted June 28, 2010 Thanks Gibvel, I'll print this out and take it home to him. Deb
gibvel Posted June 28, 2010 #4 Posted June 28, 2010 You'll probably have to reset the stations. That's a whole other and more difficult operation but, once you know how, it's fairly easy.
SevenFour Posted June 28, 2010 #5 Posted June 28, 2010 I believe it did change from Headset to Speakers when I recently changed my battery. You might want to double check the volume also after changing back to HS before putting the helmets on. Mel
