safetyguy Posted June 27, 2010 #1 Posted June 27, 2010 http://www.venturerider.org/forum/showthread.php?t=37971 (look at first post) In one of the old Shindengen regulator/rectifier threads, someone mentioned using a XV535 regulator/rectifier on a VR. Since I have an XV535 with a dead R/R, is it possible to use one of the Shindengens that were part of the group buy (from last year) to replace the dead one? The connectors look different to me but maybe I need to be more creative. (And yes, on the Virago 535 I have, the R/R is buried on the backside of the engine and very difficult to get a good look at the rectifier itself.) Another reason that I ask this question -- the XV535 R/R is allegedly the same as the one listed for that vintage VMAX. Could it be the same as the original R/R for the VR?
jasonm. Posted June 27, 2010 #2 Posted June 27, 2010 The Shingy R/R can be used on most bikes from Yamaha. Actually any bike w/3 white wrie stator input.
SaltyDog Posted June 28, 2010 #3 Posted June 28, 2010 NOT completely true. The shindegen regulator/rectifier is only for 3 phase (3 wires) stators WITH Permanent Magnet rotors. IF the rotor is externally excited (i.e. with slip rings and brushes) then you need another type of regulator/rectifier.
safetyguy Posted June 28, 2010 Author #4 Posted June 28, 2010 Thanks for the info -- let me research what is in a Virago 535 before I try buy some connectors and attent to mount the Shindengen.
jasonm. Posted June 29, 2010 #5 Posted June 29, 2010 SaltyDog said: NOT completely true. The shindegen regulator/rectifier is only for 3 phase (3 wires) stators WITH Permanent Magnet rotors. IF the rotor is externally excited (i.e. with slip rings and brushes) then you need another type of regulator/rectifier. usually brush types on 'cycles only have 2 brushes. Simply if you have an 3 wire internal engine stator it should work. And it will work on the 535. As your 535 has the same electrics as my old 550.
