Guest PlaneCrazy
Does anyone know a part number or a source for a male plug that will fit the AUX DC output that is tied up beside the battery? I have a heated vest I want to get rigged up but the ends are different and I'd much rather splice the right style of plug on the vest then mod the bike's wiring. Thanks.
If your vest is a Gerbing or Warm-n-Safe the battery side plug is available through them, and just add it to the terminals ( and fused )
Guest PlaneCrazy
Ya, that will be plan B if I can't find the plug to go with my bikes AUX output. I have a Gears Canada vest and I kept the battery harness from my old bike so I could hook that up if all else fails.
Guest PlaneCrazy
Thanks for the link! Now that I have some part numbers and brands, I think I may have a local source for those connectors. Going to check them out on Monday.
Guest PlaneCrazy
  V7Goose said:
You might want to just take a look at this post in the tech library - you can simply tin the ends of the wire and use the cap on that plug like the plug you are looking for:
http://www.venturerider.org/forum/showthread.php?t=38187
Goose
I thought about that, but I think i can actually get the pins themselves for it. I'd never just use tinned wire... I work with aircraft everyday and I'm a bit of a perfectionist with wiring and stuff. If I couldn't end up with the right hardware, then I'd just cut the stock one off and wire in an aircraft style one with enviro splices. I'd really like to have a couple of extra connectors for anything else I may use down the road. I also still need to hook the trickle charger connector to the battery by the end of this season, but no rush on that.
