just wondering if anyone has info. on how the bike should be wired for a 5 wire flat plug. Left signal, Right Signal and ground are easy enough. I want to concentrate on the brown and blue wire and what they should be connected to on the bike.
Just going over the wiring to make sure it was done properly from the previous owner.
Attached is a schematic I did a while back for a 5 wire hookup on an RSV.
It does not have wire colors on trailer portion though.
The Yellow wire on the brake/tail lights is the brake circuit. The Blue wire on the brake/tail lights is the tail light circuit.
Gary
This is what I have for cutting the wiring harness out, and re-wiring Tail lights for the Trikes. I will just give the Bike side.
Blue = Run
Black = Ground
Yellow = Brake
Brown = Left Turn
Green = Right Turn
