Sideoftheroad Posted June 22, 2010 Posted June 22, 2010 just wondering if anyone has info. on how the bike should be wired for a 5 wire flat plug. Left signal, Right Signal and ground are easy enough. I want to concentrate on the brown and blue wire and what they should be connected to on the bike. Just going over the wiring to make sure it was done properly from the previous owner.
dingy Posted June 22, 2010 Posted June 22, 2010 Attached is a schematic I did a while back for a 5 wire hookup on an RSV. It does not have wire colors on trailer portion though. The Yellow wire on the brake/tail lights is the brake circuit. The Blue wire on the brake/tail lights is the tail light circuit. Gary
kj5ix Posted June 22, 2010 Posted June 22, 2010 I have the wire color, and designation at the shop. I will get it and post it later this afternoon.
kj5ix Posted June 22, 2010 Posted June 22, 2010 This is what I have for cutting the wiring harness out, and re-wiring Tail lights for the Trikes. I will just give the Bike side. Blue = Run Black = Ground Yellow = Brake Brown = Left Turn Green = Right Turn
