Bobby G Posted June 22, 2010 #1 Posted June 22, 2010 Anyone ever use this gas additive? It looks like it contains the same ingredients as Seafoam, but a 15 oz. can was only 2.98 at Walmart vs. 8.95 for the 16 oz. Seafoam. Berryman has been in business since 1918 and is located in Arlington TX.
tsigwing Posted June 22, 2010 #2 Posted June 22, 2010 Anyone ever use this gas additive? It looks like it contains the same ingredients as Seafoam, but a 15 oz. can was only 2.98 at Walmart vs. 8.95 for the 16 oz. Seafoam. Berryman has been in business since 1918 and is located in Arlington TX. I've used it. Can't say if it is any good or not, but my mechanic neighbor suggested it.
Monty Posted June 22, 2010 #3 Posted June 22, 2010 It is about the best fuel system cleaner out there. Right up there with Sea Foam. It used to be pretty expensive, but the price has dropped considerably for some reason. Berryman makes several products for fuel systems, but I've only used the B-12 Chemtool. I have used it for years.
jfoster Posted June 22, 2010 #4 Posted June 22, 2010 I haven't used in my m/c, but I use it in my patrol vehicle. Smells like paint thinner and burns like hell, if you get it on you.
Bobby G Posted June 22, 2010 Author #5 Posted June 22, 2010 I figured I'd try it out in my F-150 first, since I'd never used it before, to see if it makes any difference in performance or milage. If it works at all, it's a steal at that price compared to Seafoam.
texasrices Posted October 24, 2011 #6 Posted October 24, 2011 Seafoam at $9.99 each versus Berryman B-12 at $3.98 each. Wow!!! Would you use the same amount as Seafoam? No difference except the price. Right?
V7Goose Posted October 24, 2011 #7 Posted October 24, 2011 B-12 is considerably more harsh than Seafoam. It may be a good cleaner (I do not know for sure), but it is absolutely not the same as Seafoam. Just one item on the label will illustrate that - Seafoam is recommended for diesel engines, B-12 cannot be used in them. Personally, I would try B-12 at the label recommended dose if I was going to run the full tank through in one day, but I would not put it in there and let it sit for several days/weeks to use up the tank in casual riding - I just do not trust it around the internal rubber parts. Goose
Squidley Posted October 24, 2011 #8 Posted October 24, 2011 I have used B12 for years and when Seafoam went out of the cottin pickin minds with the price I went right back to B12. I wouldn't use it as a gas stabilizer for vehicles sitting up, use Stabil for that, but to clean out a set of carbs....you bet!
rod Posted October 25, 2011 #9 Posted October 25, 2011 My grandfather was a mechanic and that is what he used. Like others stated it is harsh and can eat some rubber parts if you spill it. No problem for the neoprene in the carbs. I get it by the gallon for rebuilding and use Seafoam to put in the tank. Use in ventilated area and don't leave it on you skin. Rod
Yammer Dan Posted October 25, 2011 #10 Posted October 25, 2011 I use the Berryman's for major cleaning. Sea_Foam is a Maintenance tool. If you use the Sea-Foam you won't need the Berryman's. I too would not leave Berryman's sit in carbs for long. I have left the Berryman's overnight in extreme cases where they were plugged good. I have done Sea-Foam soak for a week. Sea-Foam will not harm them but I'm not too sure about the Berryman's over extended period.
jakester Posted October 25, 2011 #11 Posted October 25, 2011 I have used b-12 on trips as a additive. The first time i broke 50+ mpg it was using b-12. Have used it for years in everything but diesels. It works for me. Keep both seafoam and b-12 handy. Bill:thumbsup2:
