flb_78 Posted June 22, 2010 #1 Posted June 22, 2010 Tooling along I-64 in Southern Indiana near exit 39 and my Venture quit moving forward. Engine still runs, but bike will not move forward. Bought a trailer at tractor supply and found a pickup to tow it the rest of the way to Waynesburg, KY. Im not moved in yet and I have not had a chance to check out the problem, but when the bike is in gear, there is a terrible noise either coming from the middle gear section or the final drive itself. It's so loud that I cannot tell where it's coming from yet. This was done on the side of the interstate waiting on help. Well anywho, I'm in Kentucky now in a motel waiting for some lectricity at the house. Once I get moved and settled in, I'll tear into the bike. 99 Venture with 99,600 miles on it.
dingy Posted June 22, 2010 #2 Posted June 22, 2010 Possibly a universal joint or a snapped drive shaft. Splines in rear end may have let go. Gary
flb_78 Posted June 22, 2010 Author #3 Posted June 22, 2010 yessir, I was thinking the u-joint as well or a possibly snapped drive shaft. Im really hoping it's the final drive though as I have an extra in the moving container when it shows up.
oldguy Posted June 22, 2010 #4 Posted June 22, 2010 Sounds like the thread and nut portion at the U-joint sheared. I have come across a couple repairs like that on customers bikes.
Guest tx2sturgis Posted June 22, 2010 #5 Posted June 22, 2010 What are you doing in Kentucky? And yes, I'd bet $50 its the rear drive unit. Seriously, what are you doing in Kentucky?
flb_78 Posted June 22, 2010 Author #6 Posted June 22, 2010 http://venturerider.org/forum/showthread.php?t=49424 Did you miss this thread? I moved here.
Guest tx2sturgis Posted June 22, 2010 #7 Posted June 22, 2010 flb_78 said: http://venturerider.org/forum/showthread.php?t=49424 Did you miss this thread? I moved here. Well HELL! Yes I did miss that one...didnt know you moved...well no wonder you aint been at the biker breakfast or answering my texts! Well I guess now I have a reason to ride over that way! Best of luck to yall!!!
flb_78 Posted June 22, 2010 Author #8 Posted June 22, 2010 I still have the same phone number so your texts should be coming through, but I haven't received any from ya.
Guest tx2sturgis Posted June 22, 2010 #9 Posted June 22, 2010 I's jes tryin to make ya feel bad, fer not tellin me....
friesman Posted June 22, 2010 #10 Posted June 22, 2010 (edited) oldguy said: Sounds like the thread and nut portion at the U-joint sheared. I have come across a couple repairs like that on customers bikes. The noises youre talkiing about is exactly what happened to mine a couple of years ago at Venture West, snapped just behind the nut at the ujoint and then the pinion got out of align and took out the final drive gears totally. I hope its easier than that for you, but I am betting you will see something like this....... http://picasaweb.google.com/friesman1/85Venturerebuild_Nov11_08#5267995040305192498 Brian Edited June 22, 2010 by friesman
Rocket Posted June 22, 2010 #11 Posted June 22, 2010 friesman1 said: The noises youre talkiing about is exactly what happened to mine a couple of years ago at Venture West, snapped just behind the nut at the ujoint and then the pinion got out of align and took out the final drive gears totally. I hope its easier than that for you. Brian Nope, yours took out the middle gear assy.... Engine was upside down on a bench, in pic below.
mini-muffin Posted June 22, 2010 #12 Posted June 22, 2010 When muffin got the 83 it had the same problem. Pull pumpkin and drive shaft look at the large end of shaft ours wore out the cup. Lack of lubrication wore out the teeth on both the cup and the shaft at the normal mating point. Inspect that area well hopefully that's what the problem is. No I didn't come up with this myself Muffin dictated. Margaret
flb_78 Posted June 30, 2010 Author #13 Posted June 30, 2010 mini-muffin said: When muffin got the 83 it had the same problem. Pull pumpkin and drive shaft look at the large end of shaft ours wore out the cup. Lack of lubrication wore out the teeth on both the cup and the shaft at the normal mating point. Inspect that area well hopefully that's what the problem is. No I didn't come up with this myself Muffin dictated. Margaret Well, Finally took the time and tore it down. Found that where the drive shaft splines into the final drive unit no longer has splines in it. Luckily, I have an extra final drive unit so a quick search on ebay will get me a replacement shaft and hopefully I'll be mobile fairly quickly!!
mike_kelly_68 Posted June 30, 2010 #14 Posted June 30, 2010 Go to PINWALL cycle on fleabay he is probably your best bet.
flb_78 Posted June 30, 2010 Author #15 Posted June 30, 2010 Just ordered a used one from Pinwall for $40 shipped. Hopefully they can find my new address here in Kentucky because I can still just barely find it!!!
GlennTuc Posted June 30, 2010 #16 Posted June 30, 2010 flb_78 said: Just ordered a used one from Pinwall for $40 shipped. Hopefully they can find my new address here in Kentucky because I can still just barely find it!!! Welcome to Kentucky!!! Home to good whiskey, pretty horses, and fast women,.....er..., something like that. Hope ya's time here gets better. Hate to see you start out with motorsickle problems right from the get go. Anyway, welcome. If you get to the western part of the state, look me up. Numbers in the contact list. Glenn
LilBeaver Posted July 2, 2010 #17 Posted July 2, 2010 flb_78 said: Well, Finally took the time and tore it down. Found that where the drive shaft splines into the final drive unit no longer has splines in it. Luckily, I have an extra final drive unit so a quick search on ebay will get me a replacement shaft and hopefully I'll be mobile fairly quickly!! So what would cause that? Too many wheelies? Or just 100k Miles?
gunboat Posted July 2, 2010 #18 Posted July 2, 2010 dame forrest i missed this post about your move. went to md and came back thru ky from east top west by the park way. sorry to have missed ya. reguards don c.
Rocket Posted July 2, 2010 #19 Posted July 2, 2010 LilBeaver said: So what would cause that? Too many wheelies? Or just 100k Miles? Splines not lubed, will cause the wear.
flb_78 Posted July 8, 2010 Author #20 Posted July 8, 2010 Rocket said: Splines not lubed, will cause the wear. Yup, Poor maintenance on my part. All better now though, new used driveshaft and a new used final drive, some moly infused lithium soap based grease and a drizzle of 85w140 gear oil fixed the problem. Sorry for the bad pic. My camera doesn't like closeups even on the closeup setting, but I think you can still see the wear on the splines. The final drive looks like they've all been pushed over.
RedRider Posted July 8, 2010 #21 Posted July 8, 2010 How do you get that out of the pumpkin? I tried to remove it during last winter's maintinance and was not able to. Is this spline not lubed by the rear end gear oil? RR
flb_78 Posted July 8, 2010 Author #22 Posted July 8, 2010 No, that spline is not lubed by the rear gear oil. The drive shaft is completely separate from ANY oil. I just pulled the final off and then pulled the driveshaft off the final.
Flyinfool Posted July 8, 2010 #23 Posted July 8, 2010 RedRider said: How do you get that out of the pumpkin? I tried to remove it during last winter's maintinance and was not able to. Is this spline not lubed by the rear end gear oil? RR I also thought that the spline was lubed by the rear end oil. Or at least it is on my 1st gen. When I pull out the drive shaft I can (and did ) dump all of the oil out of the final drive through the drive shaft hole. Is it possible that you had a low oil level in the final drive causing insufficient lubrication to the spline? Jeff, to remove the drive shaft you just pull real hard. BUT, the reason it is coming out hard is because the oil seal is dried and all but glued itself to the housing. Plan to have to replace the seal if/when you do get it to let go.
flb_78 Posted July 12, 2010 Author #24 Posted July 12, 2010 I also found out the rear wheel can be removed without a jack. I have a Freebird center stand. Put it on the stand, tear it down and pull the axle out, remove the final drive and the wheel and tire will come out.
