BigBear Posted June 21, 2010 Posted June 21, 2010 A couple of weeks ago, I pulled the rear wheel, differential and drive shaft to do the typical maintenance items. All came apart as expected, and all went back together as expected. Question -> Is there any kind of rear wheel alignment that has to occur? Or does the bolt-up procedure insure proper rear-wheel alignment?
M61A1MECH Posted June 21, 2010 Posted June 21, 2010 Walt I just emailed you the service bulletin on aligning the rear wheel to ensure there is no popping noise while backing up. Other than that I am not aware of any "alignment" procedure. Good luck.
KiteSquid Posted June 21, 2010 Posted June 21, 2010 You can download the factory service manual for FREE from the link in the VRTech section to read all the factory maintenance procedures. HOWEVER there is an occasional error, like in the carburetor synchronizing procedure they number the carbs incorrectly...... gotta love Yamaha.
Jeff kelton Posted October 15, 2021 Posted October 15, 2021 On 6/21/2010 at 12:09 PM, M61A1MECH said: Walt I just emailed you the service bulletin on aligning the rear wheel to ensure there is no popping noise while backing up. Other than that I am not aware of any "alignment" procedure. Good luck. Can you please send me some info how to reuline the rear tire ? My bike filles like the bike is moving side ways when give it gas On 6/21/2010 at 10:55 AM, BigBear said: A couple of weeks ago, I pulled the rear wheel, differential and drive shaft to do the typical maintenance items. All came apart as expected, and all went back together as expected. Question -> Is there any kind of rear wheel alignment that has to occur? Or does the bolt-up procedure insure proper rear-wheel alignment?
videoarizona Posted October 16, 2021 Posted October 16, 2021 Jeff, Did you look in the tech section for the manual? The procedure is there.... David
