tpalshadow Posted June 21, 2010 #1 Posted June 21, 2010 My bike fires up every time (rarely any clutch) and idles right away at 1,000 RPM, when cold. As it warms up the idle will slowly go up to 1,500 where it will then idle there. It is obviously too fast and downshifting doesn't seem to slow the bike down enough. My question is will a carb tune clear this issue up or am I looking at a bigger problem? If I recall I set the idle before doing the tune, so should I set it when the bike is fully warmed up, then do the tune and then set the idle again? Thanks for any input.
MasterGuns Posted June 21, 2010 #2 Posted June 21, 2010 Yes, the idle must be set when the motor is at normal operating temp otherwise you get what you have. When starting cold you will need the choke to keep it running. These things are notoriously very cold blooded. Good luck.
CrazyHorse Posted June 21, 2010 #3 Posted June 21, 2010 My bike fires up every time (rarely any clutch) and idles right away at 1,000 RPM, when cold. As it warms up the idle will slowly go up to 1,500 where it will then idle there. It is obviously too fast and downshifting doesn't seem to slow the bike down enough. My question is will a carb tune clear this issue up or am I looking at a bigger problem? If I recall I set the idle before doing the tune, so should I set it when the bike is fully warmed up, then do the tune and then set the idle again? Thanks for any input. Warm it up good reset the idle.
Condor Posted June 21, 2010 #4 Posted June 21, 2010 My bike fires up every time (rarely any clutch) and idles right away at 1,000 RPM, when cold. As it warms up the idle will slowly go up to 1,500 where it will then idle there. It is obviously too fast and downshifting doesn't seem to slow the bike down enough. My question is will a carb tune clear this issue up or am I looking at a bigger problem? then do the tune and then set the idle again? Thanks for any input. Yes....... The sync will sometimes affect the idle...
