Condor Posted June 23, 2010 #26 Posted June 23, 2010 When two oils are mixed and one uses acid based tech, and the other uses alkaline base tech, it actually causes foaming. Or a dead 7 explosion....
ctraylor Posted June 23, 2010 #27 Posted June 23, 2010 Curtis if you dint want us to ask why bring it up:stickpoke: You going to be able to make the Hub Rally end of July29-30-31? or will classes be going again? I can make that one. My classes don't start until Aug. 15. As for the oil I used Castrol 20 W 50 in my Venture and the clutch started slipping. I immediately changed to Rotella Diesel oil and it stopped slipping after the second change. I thought I had ruined the clutches.
