concord006 Posted June 17, 2010 #1 Posted June 17, 2010 Has anyone vented the filler tube by the gas cap on a 1st gen? It takes a long time to get that sucker full to the top. I've seen the 2nd gen pics but no 1st. 83' VR Brent.
GeorgeS Posted June 17, 2010 #2 Posted June 17, 2010 There is a hose, top of tank, near filler neck. Remove the hose, at top of tank, and you will find a brass insert, with a very small hole drilled thru it. Check to make sure the small hole is " Not Plugged " . A few folks have found it plugged.
