Yesterday I decided to get out and replace a hatch port on a dinghy I have listed for sale. It came with just the ring. The screw in center disc was missing. The new port was about a 1/4" larger than the OEM ring. No problem, I have a Roto-Zip... The Zip came with a circle cutter that I've never had the chance to use, but it looked simple enough. The plan of attack was to cut a hole in a piece of plywood and then use it as a guide along with a veining bit to enlarge the hole in the dinghy. Well... let me tell you... that thing sucks. I started with a piece of ply about 4' long, and ended up screwing up the entire piece. But.... I did end up with 5 side stand discs... And I bet you thought this thread wasn't going to be motorcycle related.... :whistling::sign20:
I have no clue what you're talking about .... "hatch port", "Roto-Zip", ... well ok, I DO know what a sheet of plywood is.... :rotf: :rotf:
Arg Matey... Spoken like a true land lubber :rotfl:
  BuddyRich said:
Roto-Zips are miniature routers. If you try using it going in the wrong direction it'll get away from you.:rasberry: :rotf: Been there done that.
hmmm... I wonder if this would save me some space in my server cabinet...??? How many ports can you get them with? Are they capable of up to 1000mb?
More like 30,000... rpm. :crackup:
Probably not even up to, string & tin cans level......
another question or three... are they rack mountable and are they auto-speed selectable (10-100-1000 mb) ??? Are the ports managed or un-managed?
A Nerdy Land Lubber..... :sign20:
  Condor said:
It's an original 7' Lyle Hess 'Fatty Knees'.....
OK... so I admit... I know what a dinghy is but geeeeeez ya'll... I never knew they had LEGS!!!
Hey All
Just a short 6hrs till im done with work till after MD. My only hope now is nothing crashes in that amount of time it would delay my date with mant day. LOL
Bull463
Yep... Dingy Land Lubbers have legs.... I think.... :confused07: :rotfl:
Yes, yes and yes!! you can put them on a rack if you wish, or a shelf, or in a cabinet, closet or whereever. they have infinite speed adjustments and you have to manage what you put in the port:witch_brew:
Must have been a left handed Roto-Zip Condor was using cuz my right handed one works fine. :rotf:
  oldgoat said:
condors playing with his dinghy:think:
I wouldn't call it a dinghy, he's too old to be playing with a dinghy,,, don't know what you would call it now that he's been at it with a Roto Zip,,,, probably won't call it anything, because it wouldn't come anyways.
I'd compare it to a prune... all shrivelled up ... :rotf: :rotf: :rotf: :witch_brew:
