Oldslow Posted June 14, 2010 #1 Posted June 14, 2010 10,000 miles and I get a noise like a rock is caught but I don't believe that's the issue. Need to take the calipers off and have a look. Would the pads be worn out already? They have indicators for wear? As an aside, we did a beautiful overniter into Kalispell MT thru Eureka. What a gorgeous couple days here!
Marcarl Posted June 14, 2010 #2 Posted June 14, 2010 If it's grinding noise, it's time to check your pads, some wear out a lot sooner than others. If it's a squealing noise it's also the pads, but this is because they are vibrating. To fix this you can buy a spray or a thin pad that goes on the outside of the pad, or if you want something cheaper, just take the pads off and then bevel the leading edge a little at about 45 degrees. It's the leading edge of the pad that 'catches' on the rotor that causes the vibration and so by doing the bevel, it eliminates that action. Carl
Scooter Bob Posted June 14, 2010 #3 Posted June 14, 2010 The fix I found for the squeal/chatter is to put some grease on the back of the pads where they contact the pistons, and also the guide areas. Just my , Scooter Bob
Yammer Dan Posted June 15, 2010 #4 Posted June 15, 2010 If it's grinding noise, it's time to check your pads, some wear out a lot sooner than others. If it's a squealing noise it's also the pads, but this is because they are vibrating. To fix this you can buy a spray or a thin pad that goes on the outside of the pad, or if you want something cheaper, just take the pads off and then bevel the leading edge a little at about 45 degrees. It's the leading edge of the pad that 'catches' on the rotor that causes the vibration and so by doing the bevel, it eliminates that action. Carl :sign yeah that: That will do it.
