venturejockey Posted October 20, 2007 Posted October 20, 2007 And what type is used in the rsv? that is the number and shape of the prongs.
Tartan Terror Posted October 20, 2007 Posted October 20, 2007 It is in the rt side battery cover. It is a 7 prong relay as it also has the TS canceler in it too.
Gold Rush Posted October 20, 2007 Posted October 20, 2007 Hey Venturejockey, What kind of problem are you having (if one at all)??? My left blinker went crazy on me about two months ago... I accused the blinker too... One of the kind gentlemen on our board quickly pointed out that it sounded more like a bad ground situation. :confused07: Sure enough. I'd lost ground to the left front bulb. Just goes to show ya -- 40 years of riding don't make us wizzards..... :smile5: Ain't these guys GREAT ?????
venturejockey Posted October 20, 2007 Author Posted October 20, 2007 Hey Venturejockey, What kind of problem are you having (if one at all)??? My left blinker went crazy on me about two months ago... I accused the blinker too... One of the kind gentlemen on our board quickly pointed out that it sounded more like a bad ground situation. :confused07: Sure enough. I'd lost ground to the left front bulb. Just goes to show ya -- 40 years of riding don't make us wizzards..... :smile5: Ain't these guys GREAT ????? No problem with the flasher or bulbs. I plan on changing to all LED running/turn signal lights. Rather than putting in load limiters for the turn signals some of the flashers will do the same thing or at least one website said so.Thus the need to know. I've added running lights to the rear turn signals but am still using incandesant bulb for the turn signal and want to use all LED's both front and back. Thanks for the info and yes, THESE GUYS ARE GREAT!!!!! I have gotten tons of info from here over the years.
Gold Rush Posted October 21, 2007 Posted October 21, 2007 Glad to see you're not having problems.. Hope the project goes well....:thumbsup2:
venturejockey Posted October 21, 2007 Author Posted October 21, 2007 Unfortunately nbw that I have looked at the flasher it has 5 prongs. So that means the company that I was considering wont be able to help me out. They only sell 3 and 4 prong flashers. So back to the drawing board. It seems that the running/blinkers on the front are too dim to me. Now that I've changed in back that system works well but I'm still using an incandesant bulb there and want all LED's without the change in blinking rate.o
Tartan Terror Posted October 22, 2007 Posted October 22, 2007 Eric actually what you want to do isnt all that difficult. You will need to sacrafice your automatic TS cancel though. I have had it done on my bike for over a year. It works great but if you need the TS cancel you will need to just install load equalizers. This is what I used from Custom Dynamics. http://www.customdynamics.com/yamaha_flasher.htm
venturejockey Posted October 22, 2007 Author Posted October 22, 2007 Eric actually what you want to do isnt all that difficult. You will need to sacrafice your automatic TS cancel though. I have had it done on my bike for over a year. It works great but if you need the TS cancel you will need to just install load equalizers. This is what I used from Custom Dynamics. http://www.customdynamics.com/yamaha_flasher.htm Thanks TT I will look into it.
Tartan Terror Posted October 22, 2007 Posted October 22, 2007 If you have anymore questions let me know. Id be more that willing to help in any way I can.
Steve S Posted October 22, 2007 Posted October 22, 2007 Eric. Would you mind letting us know which LEDs you used? And the supplier as well. I have been looking at some for some time and I think changing them will make a great winter project.
Thomas b Posted August 22, 2019 Posted August 22, 2019 Sounds like you guys might be able to help me out. Have an 06 rsv left rear blinker and dash indicator and flashers quit. Right side blinks fine on turn but not flashers. All bulbs are good. No power to the left rear bulb. Haven’t got into the wiring yet. Tbirds
