When I removed my front wheel all I needed to do was loosen the main axle bolt and remove the calipers. I mounted the new tire and put the wheel back on then torqued the bolt to 58lbs. I read on a forum about an axle clamp bolt - is there a bolt I need to tighten to secure the main axle bolt?
I have absolutely no idea what bike you have, but on the 2nd gens there is an alien-head pinch bolt located just below the axle on the right fork. The torque spec is 13 ft lbs.
Goose
Goose
I have second generation - I'll check the bolt - thanks!
The bigger question is how did you get that axle out without loosening the pinch bolt, you must have banged real good on the axle to knock it out. :crying:
Guest scarylarry
Unless it was already lose...........OH NO....
When I bought my bike it only had 6,000 miles on it and that same bolt was finger tight. Along with a lot more on the bike I should ad,so it is wise to check everything as some times I think the person putting these bikes together is asleep or a very weak fellow.
Actually, It came out with a 3/8th rachet and socket - not hard at all. Hmmmmmm -
I didn't know anything about this pinch bolt until I read this thread. Good information for I am also getting closer to replace my front tire. Perhaps by the end of this year, a new tire may already be in place. :thumbsup:
