jlh3rd Posted June 3, 2010 #1 Posted June 3, 2010 i have a garmin 265wt...i loaded what is supposed to be a rt 66 map....all that shows up in the gps are POI's..for example ...n101..n stands for new mexico.....so, to make the gps follow rt 66...do i have to put every POI in as a "via" point...
slick97spirit Posted June 3, 2010 #2 Posted June 3, 2010 Do you know if you can download routes to your unit? If so, Harley Davidson has a route planner on their website that works really well.
KiteSquid Posted June 3, 2010 #3 Posted June 3, 2010 I have a Garmin 765T and I use Mapquest to make routes, colrabite with friends on the route, and then export it to my GPS via a USB cable. EASY!!!!
jlh3rd Posted June 3, 2010 Author #4 Posted June 3, 2010 this is where my ignorance comes in...i have micro. streets and trips...older version....and maybe i can use that....i'll look at mapquest and harley.....but i really don't know what i'm doing...just like i downloaded this rt 66 program and then i go..."now what"....
slick97spirit Posted June 3, 2010 #5 Posted June 3, 2010 hit your "Where to" button. At the next page you should have a routes selection, that is if your unit allows you to download routes. There are others on the site that will chime in a be able to help more than I can. I'm sure there are some on here who have your model GPS that can answer your specific question. I'm just trying to help till they log on. In the mean time I'll do a search on line and see if I can figure out what your unit will do.
LilBeaver Posted June 3, 2010 #6 Posted June 3, 2010 jlh3rd said: this is where my ignorance comes in...i have micro. streets and trips...older version....and maybe i can use that....i'll look at mapquest and harley.....but i really don't know what i'm doing...just like i downloaded this rt 66 program and then i go..."now what".... Streets and trips can interface with the GPS to read to the computer 'where you are at' but you cannot do any route loading or whatever to the GPS from it. It is purely used as a sensor.
jlh3rd Posted June 3, 2010 Author #7 Posted June 3, 2010 slick after hitting "where to"....my choices are :..address...go home...points of interest ( POI)......recently found...favorites....intersections...extras....cities....browse map....and coordinates so it appears i don't have route load capability.....i guess...
krispy Posted June 3, 2010 #8 Posted June 3, 2010 I don't have the same model Garmin as you do (mine is a nuvi 500), but my self-loaded stuff shows up in "extras". That's where the Yamaha dealers list came into, anyway..... Larry
slick97spirit Posted June 3, 2010 #9 Posted June 3, 2010 jlh3rd said: slick after hitting "where to"....my choices are :..address...go home...points of interest ( POI)......recently found...favorites....intersections...extras....cities....browse map....and coordinates so it appears i don't have route load capability.....i guess... They're all somewhat different, but after looking at the owner's manual online, I don't think you have the route download ability. I may be wrong and believe me, someone will point that out if I am. Good Luck.
jlh3rd Posted June 3, 2010 Author #10 Posted June 3, 2010 yeh..thanks for the help....i did a google check and it appears i do not have route....
KiteSquid Posted June 3, 2010 #11 Posted June 3, 2010 slick97spirit said: They're all somewhat different, but after looking at the owner's manual online, I don't think you have the route download ability. I may be wrong and believe me, someone will point that out if I am. Good Luck. You are correct. Regretabally the Garmin 265wt does NOT have custom route capibality.
