Kirby Posted May 31, 2010 Posted May 31, 2010 (edited) Has anyone tried these on their RSV??? Sorry , can't get the link to work. They're on EBAY Item #200477756054 Edited May 31, 2010 by Kirby
wes0778 Posted May 31, 2010 Posted May 31, 2010 Link is not working for me... Try this; http://cgi.ebay.com/ebaymotors/Yamaha-Royal-Star-1-5-Handlebar-Risers-Venture-/200477756054?cmd=ViewItem&pt=Motorcycles_Parts_Accessories&hash=item2ead67ca96 I have the Barons version of these on my '99 RSV. I had to put them on as my hands are installed too close to my shoulders. This may not get you as much pull back as the Flanders bars. But these are much less expensive than the Flanders as you don't have to change hoses an cables.
Kirby Posted May 31, 2010 Author Posted May 31, 2010 Try this; http://cgi.ebay.com/ebaymotors/Yamaha-Royal-Star-1-5-Handlebar-Risers-Venture-/200477756054?cmd=ViewItem&pt=Motorcycles_Parts_Accessories&hash=item2ead67ca96 I have the Barons version of these on my '99 RSV. I had to put them on as my hands are installed too close to my shoulders. This may not get you as much pull back as the Flanders bars. But these are much less expensive than the Flanders as you don't have to change hoses an cables. Yea, That's the one's!!! Thanks
rumboogy Posted May 31, 2010 Posted May 31, 2010 I thought so...I have these exact (same vendor I think) risers. They work very well and I was extremely pleased with them...easy install. Wally
wes0778 Posted May 31, 2010 Posted May 31, 2010 I thought so...I have these exact (same vendor I think) risers. They work very well and I was extremely pleased with them...easy install. Wally The trick is to slide them in from the side. Don't try to put them in place and then lift the bars up onto them. Can be done by one person, but definitely easier with a 2nd pair of hands.
Kirby Posted May 31, 2010 Author Posted May 31, 2010 The trick is to slide them in from the side. Don't try to put them in place and then lift the bars up onto them. Can be done by one person, but definitely easier with a 2nd pair of hands. Thanks, I'm probably gonna try a set of these. What about the rubber cushions between the fairing and the bars? Do you have to make any kind of alterations for them??
wes0778 Posted May 31, 2010 Posted May 31, 2010 Thanks, I'm probably gonna try a set of these. What about the rubber cushions between the fairing and the bars? Do you have to make any kind of alterations for them?? I left the cushions out. Others have made alterations to keep them in place. (CMIKE, Where is your post on this???)
SteveP Posted May 31, 2010 Posted May 31, 2010 Here's the link to a recent thread about the rubber pads with the riser extensions installed: http://www.venturerider.org/forum/showthread.php?t=48995
Sling Posted May 31, 2010 Posted May 31, 2010 Kerby Go to the thread below it will show you what some of us have done to solve the damper problem my solution is on pg.2 post 24 there are a bunch of ways to do this in this thread http://www.venturerider.org/forum/showthread.php?t=44815
Kirby Posted May 31, 2010 Author Posted May 31, 2010 Kerby Go to the thread below it will show you what some of us have done to solve the damper problem my solution is on pg.2 post 24 there are a bunch of ways to do this in this thread http://www.venturerider.org/forum/showthread.php?t=44815 Thanks fellas, good info!!!
CMIKE Posted May 31, 2010 Posted May 31, 2010 I left the cushions out. Others have made alterations to keep them in place. (CMIKE, Where is your post on this???) Check this out http://www.venturerider.org/forum/showthread.php?p=476473#post476473
