Puckman123 Posted May 30, 2010 Posted May 30, 2010 Can someone please direct me to the post that describes how to turn off the digital tach, I can't seem to find it.
Kregerdoodle Posted May 30, 2010 Posted May 30, 2010 on what??? Can someone please direct me to the post that describes how to turn off the digital tach, I can't seem to find it.
Sling Posted May 30, 2010 Posted May 30, 2010 This is what Dingy sent out glad I saved it hope it helps Rick Originally Posted by dingy The supplier emailed me with the way to turn off the tach. He contacted the manufacturer to get this. When you do this, all information is lost that has been stored. In our case, it probably does not matter as it is being used as a tool. The meter will have to be reset each time it is to be used. It is somewhat lengthy, but here it is. Press and hold down S1 button, will show 01-05 (do not release S1 at this time), when display 05, release S1. After 8-10 seconds(at this time, the meter will flash), the meter will return to total hours, will display 0.0 hours (the meter will not flash). Then press and hold down S1 and S2 buttons, the meter will display 01-09 (don't release S1 and S2 buttons), after showing 00000, release S1 and S2 buttons, the meter will show 00000 to 99999, then return to 0.0. Now the meter is reset, after 5 seconds or so, the meter will become blank display, 0.0 will disappear.
Sling Posted May 30, 2010 Posted May 30, 2010 Just hook it up to the sparkplug lead and ground then start the engine
Puckman123 Posted May 31, 2010 Author Posted May 31, 2010 Thanks Sling, that's the one I was looking for.
