i've read lots of posts on here about buying expensive pipes , only to be disappointed with them being too loud...and now having to sell, trade ,swap, buy...and be disappointed again.....i did the same thing...with my roadhouse pipes
but i found a $5 solution to the problem that might work for others here , if you have removable baffles...........i haven't seen it mentioned here.............aside from having the baffles wrapped.....buy two stainless steel scrub pads and put one in the front of the baffle....to keep the pad from being blown out...i used a vise to squeeze a section of the baffle down....i didn't insert the baffle horizontally in the vise, but as vertical as i could get it...and pretty much in the middle.....this might do the trick for you and save the $300 - $500 pipes you just bought.....worth a try anyway....
