dunvilsteev Posted May 22, 2010 #1 Posted May 22, 2010 Quick question: My buddy is putting the clutch back together, he wanted to know " if the clutch springs are torqued to a certain setting or just good and snug"?? thanks
dingy Posted May 22, 2010 #2 Posted May 22, 2010 5.8 ft/lbs per service manual. PDF cut attached below. Gary
OddStar Posted May 22, 2010 #3 Posted May 22, 2010 Should be 71 in. lbs. - tighten in crisscross pattern.
BradT Posted May 23, 2010 #5 Posted May 23, 2010 Good and snug and they are easy to break. Use a torque wrench Brad
dunvilsteev Posted May 23, 2010 Author #6 Posted May 23, 2010 He did the torqueing ... thanks for the help guys!
