Sideoftheroad Posted May 20, 2010 Posted May 20, 2010 Guess only way to do it is try. Not sure I would be willing to be a guinea pig though. Some Venture folks swap out Venture gears for VMAX gears. Some folks swap out VTX1300 gears for 1800. Wonder if it would work to swap out Venture gears for say 1800 gears.
Squidley Posted May 20, 2010 Posted May 20, 2010 Are you talking about using gears out of a VTX 1800 in the RSV rearend?
Leadwolf56 Posted May 20, 2010 Posted May 20, 2010 Are you talking about using gears out of a VTX 1800 in the RSV rearend? Don't think you can do that, can you? I would guess putting the VMax gears in and a Dyna 3000 ignition module would make a pretty good difference.
Sideoftheroad Posted May 21, 2010 Author Posted May 21, 2010 Squid, Yup that is what I am suggesting. Like I said just a thought, not that I am actually going to try. We put some HD parts on the bike, (although they are accessories). Just makes you wonder if there are any internal parts from other manufacturers that work too.
Squidley Posted May 21, 2010 Posted May 21, 2010 Squid, Yup that is what I am suggesting. Like I said just a thought, not that I am actually going to try. We put some HD parts on the bike, (although they are accessories). Just makes you wonder if there are any internal parts from other manufacturers that work too. Interesting thought, but I'm doubtful that the pumpkins would be close to accept the different system. You might want to check what the ring and pinion #'s are for a gear ratio and see if in fact they are close to something Yamaha makes
