I tried Condor's theory of buy as you need and ended up spending far more than this.
Gary
Depends on what you're going to do. If you're doing a frame off restoration, then of course buy the assortment. Most folks can get by with clutch, middle gear, stator, and valve cover gaskets, and not all at once..... :2cents:
My 85 has a weak #2 cylinder. I picked up an engine from an 83 for $130.00 with the carbs. I want to do a complete rebuild of that engine and put it in the 85. The 85 runs good even with the bad cylinder but I want it to be 100%.
Nice price on the '83..:thumbsup2: What's the matter with #2 ?
#2 has low compression, 65 psi. I had the valve clearence checked and adjusted on all four. Then a leakdown test pointed to the rings.
Gotcha....
Hi
I've been looking for the valve cover gaskets. Anybody have any clues where I can find a good set cheap and if there are any tips on putting them on. Thanks for the help.
Ken
2nd gen valve cover gaskets will also fit 1st gen motors.
$17.80 apiece + shipping from http://www.partshark.com/fiche_section_detail.asp?section=47209&category=Motorcycles&make=YAMAHA&year=2000&fveh=943
Item #35
They have a lip around the gasket that makes them easier to install supposedly.
I didn't use them as I thought they would not be as cosmetically attractive with lip, since I was exposing the motor with the Bikini mod to side covers.
Gary
