Finally got income coming in so I can come back to a home away from home for my 86 Venture Royale!!! YAY!! :banana:
However, I have a question about swapping heads. Will a head from an 84 fit and work on an 86?
Last fall, everything was running great. Then I had a small backfire while starting the bike and I lost HALF my power. After doing a Leakdown test and Compression test, it seems I need a valve job. HOWEVER, I have a good head that was given to me off an 84. All the measurements are within specs. I just need to know if they will swap or do i need to do the valve job on the 86 and put it back on the bike? :think:
Any help will be GREATLY appreciated. I NEED to get back on the bike. I feel a part of me is missing.
Thanks!!!!
Merlin B
Westminster, CO
:bang head:
PS I forgot to say the 1984 is a 1200 CC and the 1986 is a 1300 CC. Thank MIGHT be important
Edited by Ohedron42
Forgot some info
The only real difference between the 1200 and 1300 engines is the cylinder bore (76mm vs 79mm). A simple check of the 1984 head should tell you if it will work with the larger bore. Is there enough material around the edge of the "dome" for a good seal? If so, I would guess the '84 head will work on the '86 engine.
Thanks Gary. I appreciate the help. I will let ya know if it has enough. I am thinking it will but i just wanted a second opinion.
Thanks
Merlin:fingers-crossed-emo
