GOODWRENCH Posted May 17, 2010 #1 Posted May 17, 2010 Replacing front tire and need help with torque for axle bolt and pinch bolt.are there any web sites with torque spec. For the venture. Thanks again for all your help
OddStar Posted May 17, 2010 #2 Posted May 17, 2010 From my Cylmer's, pg 107 - Frt axle = 58 ft lbs, clamp bolt = 14 ft lbs. Hope this helps.
gibvel Posted May 17, 2010 #3 Posted May 17, 2010 According to the service manual axle 56 ftlbs. Pinch bolt 13 ftlbs. So Clymers is pretty close. You can download the full service manual from: http://www.venturerider.org/forum/showthread.php?t=1828
