slick97spirit Posted May 17, 2010 Posted May 17, 2010 You'll hardly be able to tell except for the loss of fuel mileage.
Brake Pad Posted May 17, 2010 Author Posted May 17, 2010 Okay, I just had two new plugs put in, and I didn't know the bike had this much power. I don't know when this happened, since the bike had a service warranty on it for the last 2 years.
LilBeaver Posted May 17, 2010 Posted May 17, 2010 This weekend when I did some PM work on my bike, I had inadvertantly left one of the plug wires off one of the times that I started the bike. It started a little hard (meaning it had to crank a little more than usual) but I had drained the fuel out of the carbs and such, so I just figured it had something to do with that. After I shut it off, I saw that plug wire hanging off the other side - put it back on and started again, and it started right up and it was a little more smooth. With the performance difference you noticed, you may have had a bad plug.
ddoggma Posted May 17, 2010 Posted May 17, 2010 I over seafoamed my bike a while back and didnt know I lost a cylinder. Until I noticed my milage was bad and I finaly checked em at startup. Changed the plugs and its back but still not 100%. Maybe 80/85% I have a stumble getting on it from 1 thru 3rd. Not the end of the world, but It just not the same as when she is running perfect. My milage is good again and once in a while it runs pretty near perfect.... So, to answer your question...lol They will go around town pretty well on 3 cyl. You gotta take the sides off and start her, then feel the pipes...quickly Or you'll get burnt. If you have one not getting hot. Thats the bad one.
