If ya look at my picture, the left exhaust pipe is tan and the right one is darker. I havnt had a carb sync since 6/8/08. 09 the bike sat mostly and has 4000 miles on it since then. My mpg seems to be poor. My question is-- This something that a carb sync may fix or am I looking at a valve issue. The left side has always been a lil lighter since ive had the bike.
http://img.photobucket.com/albums/v405/Hazenson/2010/100_3717-1.jpg?t=1273875421
Doing a Carb. Synchronize would be one thing on my list by the looks of your tail pipe your running rich and for some weird reason Second Gen. have a problem with the #3 coil going out right side rear cylinder mine was bad and dint even know it until I got some bad gas and found it was dead
these bikes run pretty good on 3 cylinders it could be several other things that could cause your problems too
plugs - spark plug cap - carb. sync - carb. diaphragm -bad connection pigtail for pickup coils - etc
I think I would be a little more worried about that rear tire, is it me or is it looking a little used?
:Venture:
I'm just saying.......................
Ahhh the cords aren't even showing yet. Whats to be worried about? :Avatars_Gee_George:
Could be needing a sync, but the color in the pipes is generally from the mixture. Need to find someone with a ColorTune or a gas analyzer to really set the mixture properly.
RR
i agree with redrider, but also check the plugs when was the last time they were changed. also wouldn't wurt to run a can of bg 44k thru the gas tank.
don c.
