I know we gota replace the rear shock, also replacing rear bushing on swing arm,Little over 240k on bike, any reason this shock won't work, budget is real tight?
http://www.motorsportssupercenter.com/pages/catalogs/detail/17/348/1408/1419/1/0/0/1/4/90/69/331/420-series-nonreservoir-alum-body-shock.aspx
Wow, that is a great price!
Progressive makes good quality products. The only area of concern that I would mention would be that this shock is 3/4" shorter than stock. I'm trying to visualize what effect that would have on the seat height of the bike. If it would lower or raise.....hmmmm
Why don't you try it and let us know? :hurts:
Well a 420 series shock will not work. Unless the one in the picture is wrong the problem is that our shocks have a clevis on the bottom instead of the eye hole. Progressive still does not list a solution for us on their website.
As far as I know the only option is the Works shock. I did speak with Penske a few years back and they will build you one for about the same price as a Works.
