OddStar Posted May 10, 2010 #1 Posted May 10, 2010 with the help of the fantastic write-up by v7goose, everything went great and nary a leak! Did find I was able to remove the rear valve cover by sliding it back, after removing the side and middle battery covers. Used dingy's xcel sheets, and was able to reuse a few shims because of it. Also transferred all hand data to new sheet and saved as new file, so I have a record of what shims are in now. Buddyrich came through big-time, lending me the shim kit/tool. Put all my 272's and other odd ones in kit, but wanted to replenish the ever popular 270's. Went to http://www.albaaction.com , and talked to Paul there. They're no longer doing a 'shim swap', but asked him about Sudco since the Yammi's were so expensive. He called back and is now set up with Sudco, so I ordered some at $6.75ea. Will add them to the kit before I send it back. Thanks again to these members and this great site!! Between the valve adj and sync'ing the carbs, she's a new (scarry fast) ride, and good for another 50K miles.
tsigwing Posted May 10, 2010 #2 Posted May 10, 2010 with the help of the fantastic write-up by v7goose, everything went great and nary a leak! Did find I was able to remove the rear valve cover by sliding it back, after removing the side and middle battery covers. Used dingy's xcel sheets, and was able to reuse a few shims because of it. Also transferred all hand data to new sheet and saved as new file, so I have a record of what shims are in now. Buddyrich came through big-time, lending me the shim kit/tool. Put all my 272's and other odd ones in kit, but wanted to replenish the ever popular 270's. Went to http://www.albaaction.com , and talked to Paul there. They're no longer doing a 'shim swap', but asked him about Sudco since the Yammi's were so expensive. He called back and is now set up with Sudco, so I ordered some at $6.75ea. Will add them to the kit before I send it back. Thanks again to these members and this great site!! Between the valve adj and sync'ing the carbs, she's a new (scarry fast) ride, and good for another 50K miles. was this the first valve adjustment in 50k miles? how far off were they?
OddStar Posted May 11, 2010 Author #3 Posted May 11, 2010 Yep, 1st adj. Most were below spec., except 3 exhaust that were still OK.
