eazyduzzit Posted May 10, 2010 #1 Posted May 10, 2010 On my way to work, I noticed my dash lights weren't workin then I pulled over & saw my head light & Signal lts weren't working. I got to work and when I turned the bars to the left it all came back on. Is there a connection I should look at to find the problem?
eusa1 Posted May 10, 2010 #2 Posted May 10, 2010 often when folks install the wires for the passing lamps, they will run it near the steering stops where it can get pinched and damaged. turn the bars all the way too the stops and check there first. mike.
Ga Dawg Posted May 10, 2010 #3 Posted May 10, 2010 Mine went out and I tightened and cleaned the battery connection and has worked fine ever since.
eazyduzzit Posted May 11, 2010 Author #4 Posted May 11, 2010 It was an easy fix. I had taken the fuel tank off a few days before to run an intercom wire, so that's the first place I looked. Apparently I had inadvertently disturbed a connector and it was just barely together. I couldn't tell it was loose until I pulled on each connector. When I pulled on this one it fell apart. I plugged it back in and everything works.
