bluemagic Posted May 8, 2010 #1 Posted May 8, 2010 on my 89vr when i turn the throttle my headlight brightens & if I ride over an hour I get slow starts. Now I'am getting an E-4 reading on my compressor control unit. if anyone ha experince tis could you share. Thank you
dingy Posted May 8, 2010 #2 Posted May 8, 2010 Three different situations. Three different responses. Your head light brightens as you increase the RPM's and the stator starts putting out more amperage. Look at next to last post in this thread for explanation. http://www.venturerider.org/forum/showthread.php?t=42853 The slow cranking is possibly due to a poor starter ground path. Also increasing battery cables can help. Look at next post for starter ground fix. http://www.venturerider.org/forum/showthread.php?t=46890 Last problem dealing with class system could be cold solder joints in control head. Look at this link for fix. http://www.venturerider.org/forum/showthread.php?t=493 Gary
Aussie Annie Posted May 8, 2010 #3 Posted May 8, 2010 :clap2: You're a "boat" load of knowledge my friend.
