mmkleine Posted May 6, 2010 #1 Posted May 6, 2010 For those deciding on a drivers backrest. I recently purchased and installed a Bakup backrest. The installation is simple, however, an extra set of hands is helpful to avoid possibly scratching something. The pad matches the stock passenger pad closely and the overall look is clean. Seat adjustment is easy, no tools needed. The backrest is a little pricey, but the quality and look is good. To me, the stock seat is comfortable enough, all it needed was a backrest. I figured I saved $300.00 by not having to buy a Mustang seat with a backrest.
Eldermo Posted June 6, 2010 #2 Posted June 6, 2010 I am looking for a new backrest and was wondering about Utopia or Diamond R. Utopia has one for $189, you have to drill out a couple of holes I guess, and Diamond R has one, but they want $230 for it, but no drilling(not a big deal if I have to drill) I would just like to know if anybody has either one of these, or which one they would recommend. Thanks:fingers-crossed-emo
oldguy Posted June 6, 2010 #3 Posted June 6, 2010 I had a Utopia on my "89 and I would recommend highly.Bit of a pain installing but it was worth it.(they will do the install for you too,guess you have to send or bring it to them)
davecb Posted June 7, 2010 #4 Posted June 7, 2010 The Utopia mounts to the frame, the Diamond-R mounts to the rear fender. I have the Utopia. All you have to do is enlarge 2 holes in plastic so the bolts go through. It is at most, a 10 minute job.
jfoster Posted June 7, 2010 #5 Posted June 7, 2010 2nd that on the utopia...have had no problems with it. If I remember right, they tell exactly what drill bit to use to enlarge the two holes, very simple to install.
LilBeaver Posted June 7, 2010 #6 Posted June 7, 2010 I put a Utopia on mine and do not recall having to drill to enlarge the holes... But, if one would have to, it really isn't that big of a deal. The holes have little plugs in them as is, so don't let that discourage you from the Utopia. By the way, I've been real happy with mine and it has done WONDERS for my back.
tpalshadow Posted June 7, 2010 #7 Posted June 7, 2010 What model (links please) are you guys using? Thanks!
JerryT Posted June 7, 2010 #8 Posted June 7, 2010 I have the Utopia. Works great and easy install. If you go this way, remember to lay something like an old tag on the fender when you drill out the holes just to make sure the drill doesn't hit the fender. Very easy install.
Squidley Posted June 7, 2010 #9 Posted June 7, 2010 The Diamond R is a bolt on, goes in front of the passenger seat using the 2 bolt mounts that hold the seat onto the frame. It is a excellent backrest as I have had one on my RSV's in the past. Allen and Patti are great folks to deal with and donate a lot to this site, I fully recommend them. The Utopia is a nice backrest also, and this is the one that you might have to drill to install. I like the fact also that Diamond R's matches the pillowtop seats perfectly. Tpalshadow....this is for the 2nd gens, your limited to try and find a backrest for your 1st gen on ebay or possibly a member here. You also might want to consider looking for a Travelcade seat with a built in backrest. I do have one of those that needs to be recovered if your interested.
LilBeaver Posted June 7, 2010 #10 Posted June 7, 2010 Utopia: http://utpr.com/yamahalinks.html Diamond R: For RSV: http://www.diamondraccessories.com/yamaha/proddisplay.php?name=RSV%20Custom%20Drivers%20Backrest If you want a picture of the utopia on an RSV that is not on their site, speak up. I'd be happy to shoot a few pictures, including how it mounts, when I get home tonight.
tpalshadow Posted June 7, 2010 #11 Posted June 7, 2010 Tpalshadow....this is for the 2nd gens, your limited to try and find a backrest for your 1st gen on ebay or possibly a member here. You also might want to consider looking for a Travelcade seat with a built in backrest. I do have one of those that needs to be recovered if your interested. Yeah, I have a buddy who is looking for one for the 2nd gen. I would be interested in the one in need of recovery...pm me with some details if you don't mind!
Mariner Fan Posted June 7, 2010 #12 Posted June 7, 2010 I just installed a Utopia backrest minutes ago. You have to enlarge two holes to 9/32". I took a small piece of 1x4 wood to keep the drill bit from accidentally hitting the rear fender. Took me longer to read the instructions (look at the pictures..lol) and get the tools together than actually installing the backrest. Now I have to adjust it to suit my height. I've heard that if your tall, it should be positioned as low as possible so that is what I did. I'll probably fiddle with the adjustments a bit until I get it just right. http://cdn.buzznet.com/assets/users16/marinerfan/default/large-msg-127593575986.jpg http://cdn.buzznet.com/assets/users16/marinerfan/default/large-msg-127593477354.jpg
Mariner Fan Posted June 7, 2010 #13 Posted June 7, 2010 Close up of the Utopia. http://sphotos.ak.fbcdn.net/hphotos-ak-snc3/hs534.snc3/30295_1302224198760_1325100858_30683643_2585195_n.jpg
Storminyte Posted June 13, 2010 #14 Posted June 13, 2010 I am looking at both the Utopia and Diamond R driver's backrest....I know that they both adjust forward and rearward but the Utopia one looks like it's a little more difficult to adjust. Can anyone tell me how easy or difficult it is to adjust either of these? Thanks... Dee
Mariner Fan Posted June 13, 2010 #15 Posted June 13, 2010 Adjusting the Utopia is simply a thumb screw for forward and backward and a couple of bolts for up and down.
